I would like to ask your advice please lads. Powerflushing, am i carrying it as it should be . I always try and connect at the pump valves and i use fx scalebreaker,neut crystals and add inhibator. I run it without chemical for 45 min and dump 2 times,then let it dump amd leave mcw running in.THEN i add fx and run for hour, reversing as well,then do rads individually and boiler .then start dumping and add crystals until its running clear at the dump valve.any help,
