- Joined
- 10 Aug 2022
- Messages
- 2
- Reaction score
- 0
- Country
Hello, I'm replacing my Danfloss prgrammer with a Hive. The Hive can to be set to support either 'Fully pumped' system or 'Gravity fed/part pumped'. The old Danfloss programmer was set to 'Pumped' (as in the photo).
I have incuded some photos of the boiler and the hot water cylinder. There is only one water tank in the loft and the hot water cylinder is labelled 'vented'.
Should I set the Hive to 'Fully Pumped' which is the default or to 'Gravity fed/part pumped'.
Thank you for reading.
Regards
Regards
