I'm lucky(!) enough to be moving into a large old timber framed house which needs quite a lot of updating . The central heating seems to be in fairly good condition and has a Boulter Pathfinder oil boiler (45Kw), TRVs on radiators but a hot water tank about as far away from the boiler as could possibly be.
My plans are to update the boiler to gas (available just outside but not taken up by the current owners), re-position the boiler and hot water together in the central area of the house and re-do bathrooms.
I intend to get professional help doing this but as I have an engineering background I like to at least get involved in the decision making discussions.
I have done a heat calc with the Stelrad Start program which tells me that my heat loss is at the 33Kw level before a hot water load. My first reaction was this was a little low but maybe it is right. I was expecting higher.
My view is to put in a new gas boiler (Atag 51Kw?) and a (big) pressured hot water supply - possibly with an accumualtor to support it but I have not had a chance to look at pressure and flow rate yet. I do know that the water main rises just where I want to locate the plant.
Does this seem like the thinking is along the right lines? Any help and constructive opinions are appreciated.
