I rent a property that has the Amtec electric boiler to provide heating and water. It appeared to work fine for the last 4 months since moving in, then the hot water seemd to take longer to get hot. It has slowly got worse and now is only producing very Luke warm water.
It has always baffled me slightly. When the hot water is switched on, the radiators get hot...which will be inconvenient in the summer. I am unable to bleed the radiators as the valves are all painted solid and cannot be turned.
My landlady is "looking into it", but if there is a quick fix, I would like to know.
Thank you in advance for any helpful advice.
Ali
Ali
