- Joined
- 3 Jun 2016
- Messages
- 139
- Reaction score
- 4
- Country
I've had an extension on the house and the rear lounge now had about 5ft extra on it which has a new concrete floor, there used to be a bay patio window there and that was removed, it was the typical U bay shape. So the original floor board are also in the bay type shape meeting the new concrete floor (see pic).
The issue I have is the builder used a laser to measure the height of the floor however I think they measured at the far end or the middle and the floor actually sloped down a little so the concrete floor ended up around 7-9mm higher than the floor board. They removed the bay and then sloped down slightly were that was to meet the floor boards (see other pic)
I plan to have Amtico or similar in the extension part up until the original internal wall line (around 7 floor boards in) in the lounge where I will then have carpet in the rest of the room. The reason being that I will be using the bifold a fair bit so I don't want to be walking in on carpet or rug or such like. Also it gives a bit of a feeling of separation at the end of the reading area and sun area when finished.
So my issue is how to I make sure the Amtico floor is flat across the whole area including where the slight drop is to the floor boards. Also will I have any issues with the concrete being totally solid but the floor boards obviously having some slight movement.
