Hi folks
I've just bought a 2 gang RJ45 face plate to use in our new extension (Pic attached). Only problem is I haven't got a clue how to wire it...
View media item 34573
I am used to using the push down type jacks, however, this one is different and I can't figure out if you simply push the cable into the socket, or if you need to lift the plastic cover and push the cables down.
Can anyone point me in the right direction?
Also, is A or B the preferred wiring method?
many thanks
Carl.
many thanks
Carl.
