another baxi 105e leak
6 Jul 2010
Middlesex
Had my boiler a part to day to trace a leak that i've had for a couple of weeks
found it coming from between the diaphragm body and divert-er body
bought a new seal kit for the diaphragm body but it never cured it
Took the diaphragm body off and switched all water back on and have now seen it coming out of the diaphragm body where there is a small hole with a pin sticking out
see diagram
What i want to know is there a repir kit for this as i'm sure it's only a small o ring causing the problem that sits over the shaft or am i worng
thanks in advance
Correct.
I belive you can use the diaphram repair kit (contains the tiny O ring).
Be warned tho they are a swine to strip. Perhaps replacing the back section will be easier. It is available as a single part
Yep it's a small O ring causinig the problem. A far as i'm aware there isn't a service kit for this but if you could find an O ring that fits it'll probably work. You might have trouble getting it out though but worth a try if it'll save you £90 quid or so for a complete new valve.
If the repair doesn't work be prepared to be without your boiler until you get a new valve, it could leak even worse once you've messed with it!
Thanks for the quick reply guys
Think I will give it a bash tomorrow just need to get another o ring
Looking at it I might be able to do it with the diverse still in place
Saying that I doubt I'd get the old o ring out
Might just end up getting a recon unit for £30 from a local supplier
