K
keego
Only thing is, it's my own boiler!. Up to now I've tried power flushing it from a radiator & X200 with no effect, after that I gave it a power flush from the pump with all the rads & HW coil off ( left it on for 2 hours ) this cured the problem for all of 3 days.
This all started after I changed the bathroom rad to a towel rail, I never drained down because I used bungs, one valve was a straight swap the other needed a reducer soldering on but otherwise that was a straight swap as well.
The boiler is a Baxi Solo 3 50PF which is less than a year old ( the whole system is only 6 years old ), it's on a Y plan fitted with a bypass, the area we live in is a soft water area but I still have a scalemaster Gold fitted on the rising main, it's always had X100 in it until now, I've put Salamander system inhibiter in it this time..... change of employer
All suggestion gratefully accepted as I'm starting to lose the plot on this one, the boiler is below my bedroom & I'm getting tired of being woken up every morning by the bloody thing.!
