Hi all
I've recently bought a 1930's semi which needs a heck of a lot of modernising done to it and in typical moneysaving style I'm hoping to do most of it myself, so I'm sure that this wont be my last cry for help I'm a fairly new Dyer but competent and conscientious and have lots of common sense so fairly confident i can do most things myself, within reason. Probably will struggle with the building terms and wording more than anything else
My first cry for help is that the first job i would like to do is to fit new UPVC double glazing (there is a mixture of single glazed UPVC and metal windows at the moment)
I don't know much about the technical terms at the moment and am hoping to find a company that sells windows for supply only. I realise once i have fitted them myself i need to obtain a building certificate??
So i need to know what questions i should be asking the companies?
the sort of thing i was thinking is:-
do i need trickle vents or not?
what profile they use? (i realise there are better profiles than others)
what is their windows efficiency rating? (not sure of the term)
anything else i should be asking them?
thanks for your help,
