Another hotpoint aquarius thread
27 Sep 2007
Cheshire
Hi I have searched the forum and seemingly found what is wrong with my washing machine. Firstly the error codes pointed to a blocked filter so I removed that and with it a few quid in change, this rectified my problem for a few days then another error code pointing to the pressure sw stuck on empty so i removed the top blew down the hose and checked the switch which didnt seem stuck and hey presto the machine was fine for another few days. Now I have the following codes and from what I can gather i need a new pcb.
Hotpoint Aquarius WF541
Wash enhance flashing on/off flashing rapidly
Fault as posted by rock seems to be f08 light 1. heater relay
Now I have got this far can anyone confirm a new pcb or are there any further tests i can do ? What confuses me is I am only attempting to spin the load yet I am getting a heater relay fault.
Any help appretiated with thanks.
Mike
Fo8 is either heater or heater relay on pcb. Check the heater for continuity.
Remove rear white cover and it's there on the back of the drum. Its got 3 wires in it and 2 thin blue wires in the centre. Remove the outer 2 wires and check it with a meter.
Cheers rocks just checked the heater and there is continuity, to clarify the wires i checked were the brown (left) and blue (right). Does this mean it looks like the heater relay and therefore a new board ? I have used your past posts and found the supplier you recommended has one for about 60 quid.
Thanks in advance
