More help needed........
I need a switched fuse isolator (metal) rated at 80A or 100A, the problem is it need to be physically small.......
Bought a MEM excel range, got delivered this pm and the thing is massive and cant figure for the life of me another make which will be smaller.
Its to isolate an auto change over switch (job has changed from original install).....the standby board use to cover 2x 32A rings covered by a 63A MCB from the main board...now its covering 4x 32A rings (and could exceed, its ok at the moment but knowing my luck)...
So the 63A MCB is being changed for a 100A single pole MEM isolator (18mm) and then into a "switched fused isolator" to protect from over-current.......
Without going into too much detail with the above and not being able to go online tonight (laptop left in work & now sitting in a net cafe) i'm in need of some help if I cant find another make......the size I'm looking for is about the size of a 4 way board.....
Thanks in advance......and i'll buy ya's a pint, if I ever see ya's......
(Sorry if its all a bit vague)
