Hi all,
First post so please be gentle.
I know this question has been asked numerous times but as each system is slightly different, here goes.
I have an 8 year old Glow Worm micron 50F in my first floor bathroom airing cupboard, along with the hot water cylinder fitted at the same time. The Expansion Tank is in the loft above placed at floor level, the cold water supply tank for the the hot water cylinder also in the loft was raised about 5 feet a few years ago, to give me better pressure for the shower. The 2 year old pump is currently set to the lowest of three speeds. The Expansion pipe is about 1 foot to the top of the bend above the water level in the F&E tank.
Very Hot water is pumping over when the system is heating the water, this is at nearly full flow when the pump speed is on 2, & a bit less when on speed 1.
I would appreciate your help & advice regarding this problem.
Thanks in advance.
Thanks in advance.
