Can anyone help me choose the correct junction box to join 6mm t&e to 6mm swa (3 core)... I'm connecting internally before swa leaves building.....
Fair enough I just use the wiska as standard.If it's inside it doesn't need to be weatherproof, would suggest adaptable box.
Have any of yous actually used wiska boxes? The ones I use have m20 threaded entries and you'll not get a piranha nut on the back of that, they offer their own proprietary earthing clamps for use with these (which I'd recommend if you're going that route). You'd also need a gland you can make off and split or you'll end up shagging the box tightening it up. Nothing wrong with drilling through a metal box for banjo and they take more abuse. Also, what do you think "adaptable box KO" stands for?I'd also use a piranha nut to secure the SWA and link the Earths rather than a banjo & strap. A stuffing gland for the T&E
I would also opt for a Wiska as it has knockouts making it very easy to use. A slightly deeper box helps get the SWA fixed too
Ah, excellant and timely advice! Which box and gland combination would you reccomendHave any of yous actually used wiska boxes? The ones I use have m20 threaded entries and you'll not get a piranha nut on the back of that, they offer their own proprietary earthing clamps for use with these (which I'd recommend if you're going that route). You'd also need a gland you can make off and split or you'll end up shagging the box tightening it up. Nothing wrong with drilling through a metal box for banjo and they take more abuse. Also, what do you think "adaptable box KO" stands for?
Yes, if you read my post I stated you need to use a deeper one the 51mm aren't suitable. I'm fully aware what KO stands for the Wiska's are threaded.Have any of yous actually used wiska boxes? The ones I use have m20 threaded entries and you'll not get a piranha nut on the back of that, they offer their own proprietary earthing clamps for use with these (which I'd recommend if you're going that route). You'd also need a gland you can make off and split or you'll end up shagging the box tightening it up. Nothing wrong with drilling through a metal box for banjo and they take more abuse. Also, what do you think "adaptable box KO" stands for?
Do you own a crimping tool?Ah, excellant and timely advice! Which box and gland combination would you reccomend
NoDo you own a crimping tool?
