Hi all,
I have different problem with my system. When the central heating is off and cold, and I make a domestic hot water demand (shower, tap or washing machine), the water starts to heat up, then the boiler makes an awful clunking sound and the pilot goes out. Some sort of safety cut out?. I have to relight to pilot and try again, sometime it will go out 2 or 3 times. If the heating is on and hot water in the radiators the domestic hot water is fine.
I have bled the radiators and the boiler base pressure when it is cold is 0.5 bar.
Also, hot water flow from tap or shower seems quite low, but I don't know what is normal as I only moved into this house recently.
Any ideas anyone?
Cheers,
Woody
Any ideas anyone?
Cheers,
Woody
