Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
You'll need a 1/2in router (deWalt, Makita, Festool, Bosch), 30mm guide bush with centring mandrel, replaceable-tip TCT straight cutter and a decent sized jig in either aluminium (Titman) or solid laminate. The RT cutters are turned every second or third cut (so you get 2 to 3 joints out of a set of cutters - but the edge is superb). Always do your cut so that you're cutting into the laminate to avoid break-out - this translates to a left hand end cut being done with the jig on the underside, for example. Make a roughing cut then do a single final pass (the jig's manual will explain what I mean) and seal your joints with Colourfill. Best joiners I've come across are made by Projoin in Dover. They screw on flat and have a cam tightening mechanism. You'll also need a laminate trimmer and a fine metal file to deal with end strips, as well as a heat gun if you need to form the end trims at all.
