Simple question: how much damage can an ant infestation actually do to a property? I ask because we've moved into a bungalow in which the previous owner has gone round the building and slapped chunks of what looks like quick setting mortar on the outside walls, for no discernable reason other than maybe to seal random holes in the brickwork to try stop ants or other insects from getting in. The mortar doesn't match the original, so far I've found no large holes underneath it that might be caused by weathering or settlement and I've started removing it because its an eyesore. I only mention ants as the potential cause for this because since we arrived, we've spotted a nest or two at the base of the outside walls and we've treated these with gel.
Additionally, whilst decorating the lounge I found that the bottom of one of the skirting boards had extensive damage (there are no signs of damp) which had been patched up/ filled in, and I began to wonder whether it was due to damage by ants. I've heard of them causing minor damage by chewing holes to build and provide access to their nests, but never heard of them chewing away the bottom
half inch or so of a ten foot long piece of skirting. Is it possible that ants have done this? I intend to take off the damaged board and will ensure that any holes to the outside are filled in, and ant gel will be put down behind the skirting before I replace it.
Maybe when I DO remove this board, the source of the problem will no longer be open to question.
