Hi folks,
I have a bit of leak problem, wondered if anyone could hep please?
I've put a new basin in and it's to be linked to the shower/bath waste (tho it's not yet), so I put an anti vac bottle trap on which is fine, until you run a full basin, then let the water out, or fill untill it comes thru the overflow, then it leaks from the air admittance part of the anti vac trap
, like it's very full and comes out the valve area. It is 32mm waste going up to 40mm as it drops down at the rear of the basin.
Should the anti vac be able to leak from there?
I tried blowing down the trap and it's airtight, suck and it lets air in, so that seems right, isn't it?
Any help mucho apprecio
