I recently bought an Edwardian cabinet to put upstairs. I measured the doors, space for it to go into thought it'd work so bought it... but hit a snag on getting it around the first of 2 corners (and that's the easier corner).
Is there any advice on what to do? The unit is beautiful workmanship - mahogany, tongue and groove and a lot of nails. I unscrewed what I could to see if it had any obvious disassembly points but too much is nailed in.
The problem is that the legs are too long so I can't make the turn and they run the height of the unit. I can't use a hoist as the room it's to go into doesn't have a big enough window. I'm in London if that makes any difference.
Dimensions are 1020mm high x 600mm at its deepest x 970mm wide.
