Hi all. Iv already posted a few times about the heating system in my house which I bought this year but now we are in winter and the heating is on a lot a have another question I'm hoping someone can help with .
The system I have is a 16 year old baxi standard boiler and a hot water cylinder . The way the system works is the hot water can be heated on its own independent of the central heating system but whenever the central heating is on the hot water heating is also on. The problem is that my wife is home all day with my infant daughter and we have found that the ground floor of the house seems to get particularly cold and is also slow to heat up so the heating is on for very extended periods all day. There is no thermostat on the cylinder so this is also constantly getting heated. I'm assuming that this can't be good for the system? The hot water is absolutely boiling when we run it, to the point it would scold your hands if you put them under it .
What I'm wondering is if there is an easy way to fix this , I know I could put a thermostat in and I assume wire it to an isolator/switch which would cut the heating when it reaches temperature? I have been told this is expensive however . I am already considering putting in a whole new combi system in the new year so going to a fairly large expense for a few months seems pointless . I'm wondering if there's a way to just swap out the existing switching mechanism so that the central heating can be run independently? Or even a way the temperature of the cylinder could be limited through the boiler?
Thanks in advance for any help
