the expanders go on the network.
Depending on the power your using you may get an SAB on there without a PSU.
For example door contacts don’t draw much power, motion detectors can vary but don’t use much and use more if they are dual techs or multiple sensors in one unit. Network is 1A. so if you have 600mA or so to spare th at a about SAB draw in full alarm on a Non E version Odyssey.
You need to look at what your putting on the system to work it out.
for example you can have a lot of bell boxes connected it’s only when you need to fire them off the alarm, that the bell box load makes any real difference.
