Hi all, doing out a cloakroom replacing the toilet and sink. When removing the sink the 32mm waste pipe went directly into the concrete floor. Just above the concrete floor was a compression joint which sheared with only minimum pressure to try to undo. The compression joint is orange (makes me think a direct connection to main drain)? And it also looks like it had orange poured on it to seal as there is an orange "spill" surrounding the compression joint (pic 2) anyway, it has snapped flush with the floor. I need to connect the new 32mm basin waste to the orange pipe which is now sub floor. Is there a 32mm pipe liner / sleeve which can be solvent welded inside or another way? Your help appreciated.
View media item 58282
View media item 58283
