    Dismiss Notice
Anything I should Add to Wall Before Adding Insulation Board?
Discussion in 'Building' started by ILikeDIYS, 20 Sep 2019.
  1. ILikeDIYS
    ILikeDIYS
    4 May 2016
    211
    Thanks Received:
    Country:
    Clear OSB at the moment on the internal side. I have an excessive amount of DPM left over.
    Was wondering if there is anything I can add to the summer house wall before hammering in the insulation board to make the insulating properties a bit better?
    For example stapling a sheet of DPM to it, or adding that foil bubble wrap stuff?
    The insulation board I ordered is a bit smaller than the stud wall width so I have space to add something else if it's gonna make a difference.
    Cheers.
  2. nuzuki
    nuzuki
    15 May 2013
    309
    Thanks Received:
    3
    Country:
    Normally some sort of sheet goes on the outside of the studwork wall panels. I use sark IT sheet built from the bottom upwards, usually 3 strips with an overlap. Then the insulation is pressed in place from inside and OSB/ply/interior cladding over the top.
    The DPM will be useable in place of the Sark IT sheet.
  3. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
