As the title says. Right then, c/h and h/w calling for heat but all I get is a quiet humming noise when you switch the boiler to hi or lo option. I've checked the thermostats and they all seem fine, if I make the fan switch operate manually then the boiler will fire. The fan will not run though at all at any point. I have 240 going into the pcb but not coming out to the fan wires, so I changed the pcb and it's not that. Any ideas Anyone ? Cheers.
