Fairly standard scenario, loft conversion on a Victorian terrace. Managed to persuade building control that the the existing 4 panel doors can be upgraded to FD20.
Problem is BCO wants FD20 fire resistant quality to be certified by an approved contractor. Who is an approved contractor when it comes to fire door upgrade?
Google isn't throwing up any matches for "approved contractor" & "fire door upgrade". Part B1 of building regs doesn't seem to identify any approved contractor scheme.
Does anyone know what the relevant approved contractor scheme would be?
All the doors are between 37 and 45mm thick, with 10-12mm panels and 25mm jambs. What I propose doing is.
-router 4mm x 10mm intumescent strip into door
-replace ironmongery with fire rated
-install threshold and seal with intumescent caulk.
-remove the panel trim on the "risk" side of the door and cover panels with intumescent paper.
-remove door trim on risk side of the door to ensure plaster edge is upto edge of door liner
-paint risk side of door and door trim with intumescent paint to 30 minute rating.
To me none of these tasks seems technically challenging, it all makes sense and as long as I follow the manufacturer specifications for the intumescent products, I can't see what can be messed up if I tackled this lot myself and would be a fun little project. Thoughts?
What I don't want is 2 kids showing up from some big old contractor with some expensive stickers on their van and have a router running astray on 120 year old doors. Any 1 man band operators in South London?
P.s. I know these arguments are very tied but.....
1- my bedroom door is the only door that ever gets closed...whats the point?
2- victorian house, stripped pine floors throughout with 5mm gap between every floorboard, majority of doors at 90 degrees to floorboards.....whats the point?
