Yayyy...excellent, we have now established the position.
The system's been changed from gravity fed to unvented mains pressure Hot Water. Cool, ok then, if Aqualisa is stating their low pressure processors seals may fail due to the system now being mains pressure then, there
must be a difference in the unit part from the pump
New processor (ouch) required before a new ceiling is??
That may spark off another debate as to the difference between the pumped and non pumped processor, why use different seals? Doesn't really follow the mass production ethos of use as many of the same parts as possible across models to keep costs down but hey been wrong before, wish I had both to compare
Clare, for all your advice, unfortunately it had not been established that the OP's HW cylinder had actually been changed to un-vented, just that the boiler had changed from a vented to pressurised system, which could easily have been the CH/HW Boiler primary circuit.
That added to the fact that being an Aqualisa rep your ultimate recommendation was, in essence, spend lots of money with us to correct the issue, when it wasn't clear what the actual situation was. I am sure your intentions were honorable in approach but being the supplier...hmmm... I apologise if I sound a little skeptical. Clarity was required before a consensus could be reached.
