aqualisa Quartz
17 Feb 2008
Berkshire
I have an aqualisa quartz shower. When first switched on it reaches the correct temp, but minutes later goes cold, then back to normal temperature. It then runs fine for rest of shower time. Any ideas what might cause this?
Get an assistant to start the shower while you stand next to the Quartz box.
Put one hand on the hot input and the other on the mixed output.
At the moment that the output goes cool, what temperature is the hot input?
If hot, then call Aqualisa, because they provide a 5-year on-site warranty.
If cold, then your problem is that the hot supply is going cold, i.e. the fault lies outside the Quartz shower.
