I've pretty much got this installed save for reboarding the studwork and mortoring in the pipes in the wall, but want to check a few things before I do that. I've a gravity fed system (tank in loft, HW cyclinder at first floor level) with twin impellor pump fed with 22mm into 15mm flexi's, with 15mm flexi's out continuning in 15mm pipe for a metre or so to the valve inlets (H+C 15mm). Single outlets (15mm) to bath filler and shower.
Q1. Should I expand the shower pipework out to 22mm from the shower outlet, only to reduce again at the head to 15mm for a run of 1.5m with 3 elbows.
Q2. The temperature of the hot is hot enough to the touch but not as hot as I like. It's connected correctly on the valve, the HW cylinder is working ok at 65 degrees. I'm wondering if the Architeckt Avus range have a safety device to avoid scalding? Could I remove this? Does anyone know how to contact the manufacturers as I can't find any info on them?
Q3. Surrey, Warwick flanges. Some invalidate the pumps but with a HW cylinder with a 3/4" top outlet most won't fit. Any ideas? I used a techflow one once but seem to remember cutting a hole in the tank to fit it? Can I avoid doing this as I can't find one samll enough (probably due to restricted flow through the top hole)
Thanks for any suggestions in advance.
El
El
