I have a 1920's hot water radiator system in my house. Recently I had a plumber do some work, and he installed the radiator backwards from the way it was before. now it makes a tapping noise. I have two theories of what may be causing the tapping noise.
1. It might be the pipes below the radiator are expanding/contracting, and maybe wrapping them in foam pipe insulation would help keep it from tapping?
2. It might be that the radiator is not bi-direction, and the plumber installed it backwards.
Please let me know if you can install these radiators backwards? The way it is now, the air release valve at the top is on the same side where the hot water is entering the radiator from the boiler.
Thanks for your help!
