- Joined
- 6 Feb 2012
- Messages
- 9
- Reaction score
- 0
- Country
We have recently had a complete new central heating system (boiler, pipes, radiators...the lot) fitted and we are having trouble with the boiler not coming on at the time the thermostat is set for.
The boiler is a Vaillant ecoTEC and the thermostat is a Honeywell CM727 Wireless.
I have the thermostat at 16 deg c for overnight, then for 20 deg. c at 6.50 am. This very rarely works as sometimes the boiler doesn't start up until at least half an hour later and even then it will heat a small part of the radiators, then stop for a few minutes, then continue like this until it finally works properly. Sometimes the "burner on" symbol is displayed on the thermostat, even though the boiler isn't heating anything.
This morning, it worked perfectly...the pipes and radiators were heating up dead on time. Yesterday, nothing happened until 7.30am and that was when I got sick of waiting and switched the thermostat from auto to manual for a while.
Can anyone tell me if this is normal, or is there a fault with either the boiler or thermostat?
The boiler is in the loft and the thermostat is normally in the lounge, downstairs. I've tried replacing the batteries in the thermostat & that doesn't make any difference. Usually, the temperature in the room where the thermostat is, would be around 17 deg c at 6.50am, so the room temp needs to be raised by about 3 deg.
