Short version: Ripping out very old kitchen, a particular cupboard ground level has always smelled damp inside, its wooden sides were its legs and it fell apart when i messed with it, it was very damp damaged on one side in particular, images attached. Wall behind it is obviously very damp in the corner, next to the main water main and stop tap, and where the pipes go into and under a concrete floor to the other side of the room where the provide hot and cold water to sink, washing machine and dish washer. Wall has salty deposits on it, im guessing its been this way for some time?
a bit more detail, the damp point is a join between an extension and the main house, in the inside corner of an L shape, however, the kitchen side of the corner is damp, but the dining room side of the L is dry this makes me think that its less likely the damp is from the outside, as if water was pooling in the corner outside surely it would get both walls? the dining room sits on a raised wooden floor, which is clean and dry looking at it but i cant see the wall. the kitchen floor has been filled in with concrete which spans into the extension part. The extension is 2 story and there is no sign of damp from the roof in the bedroom upstairs but ive yet to properly inspect it, but the roof looks in good shape, ive been up there and inspected it in the summer, not that i'm any kind of expert. Also the ground level is defo below the damp course. although im sure that doesnt always stop it.
there is no other damp along that wall or along the floor only near the pipes, but the damp does seem to be off to the right of the pipes, not surrounding the pipes, but i suppose the bits surrounding the pipes were ventilated where as the bit thats damp was covered by the old kitchen which could explain it, anyway, take a look at the pictures?
im fitting a new kitchen soon and dont really want to fit over damp walls, which is one reason i need to cure it, also im having all the pipes except for the mains pipe moved and they will go through the ceiling instead of the floor, due to me moving the boiler. so im hopeful it will dry out, How will i know its drying out as ive seen mention in other threads of removing the plaster.
thanks
Pipes on the left of the image
the below image shows the damp patch line, you can just see where it drys out below the wallpaper, which just fell off the below.
you can see the white stuff on the wall in the area
thanks
