Are the two radiators in the links effectively the same? From the pictures they look identical. The only difference seems to be that the more expensive one has a slightly higher stated BTU output.
Lux Heat
Faro
The Lux Heat link just takes you to the options window. You need to select 1800mm x 350mm to see the equivalent model to the Faro.
Thanks.
Lux Heat
Faro
Thanks.
