Hi all,
Putting in a new kitchen yesterday which meant altering some pipe work, I'm not a plumber but I do have a bit of experience with soldering, I was putting some end feed 22 x 15 x 22mm tees on yesterday. I did think the 22mm sides felt a bit loose on the pipe, they were brand new fittings (endex brand) and the pipe was brand new 22mm Wednesbury pipe, they had quite a bit of play/wobble on the pipe, I happened to have some other 22mm x 15mm tees in my box think they were toolstation own brand and they weren't much better still a fair bit of play, so thought I'll just go ahead and solder them up hope for the best!
Well all the joints are watertight and have been overnight, but they have these gaps at the top of the joints on two of the 22mm sides of the tees, I'll attach pics, but just wanted your thoughts is this anything to really worry about if they're holding water no issues? Its just not the nice ring of solder you usually see, no doubt this is due to the fittings and pipe being a bit of a loose fit but as I say I tried two different brands of 22mm tees and two different lengths of 22mm Wednesbury pipe from different stores and every combination was looser than I'd have liked! Appreciate your thoughts please
