I've read through a lot of problems with the 23 MFFI but not found any like mine yet and wondered if anyone had suffered the same or knew what the problem is
Recently moved in and this 4year old combi was already there, and seemed to work fine, though noticed primary water pressure was near 0 (previous owner had neglected to top up). I have since added water to 1.5bar and bled the air from the rads.
A few weeks later, from cold, heating and DHW fire the boiler up perfectly, as soon as a tap is turned the burners are alight.
However, if there is any residual heat in the boiler (say after heating just switched off, or hot tap recently used), when a tap is then switched on (or heating requested), the pump and fan seem to start up straight away, but the burners do not light. Eventually they light but often up to a minute after the water has started running cold. Once alight, everything seems fine, water is the right temp etc.
The only thing I have changed is adding an external thermostat but that is working fine.
I have checked that the diverter valve is working, and it is definately striking the micro switch (as that is causing the pump and fan to start), so guessing problem is in the primary circuit somewhere (as this effects both heating and DHW)
What else is it checking before lighting the burners, that could be effected by residual heat. I have not checked the air pressure switch yet, but could not really see how that would be effected by heat???
