Ariston Margherita 2000 rattling drum
23 Mar 2008
Yorkshire
The machine seems to have something small and hard or metallic, trapped between the perforated drum and the outer drum housing. It makes a right racket when the spin cycle starts, but I can hear it if I rotate the drum by hand. It's 'just there' if you know what I mean.
It's probably a coin or a bit of the wife's jewellery, though god knows how it got in there.
In all respects, the machine is working fine, it's just noisy, so I'm convinced it's a foreign body, not a bit of the machine.
Thing is, how do I get it out? Can I get to it via the seal, or is it a back off job?
If its something between the drum & tub don't use your machine until you get it out. If you're unlucky a coin (or something similar) can punch a hole clean through the tub, wipe out the heater element...or both. Several ways to get foreign objects out;....remove a drum paddle, take off the sump hose, or remove the heater element. Your choice...
