I rent a flat and the radiators make vibration noises - a very loud hum. It is loud in the flat, but it is *extremely* loud for the downstairs neighbors. The radiators themselves don't shake or anything, though.
One radiator vibrates loudly almost hourly when the heat is on. The bedroom radiator make the noise once every few days. The bathroom one does not seem to make noise.
In the autumn, my landlord said it was because I was running the heat too often or too high. I never had this problem at my last flat, about the same age, so I do not understand the logic. He's the landlord, so I did as he requested and put the timer on for heat a few hours a day.
Besides being cold, this has not helped. Oddly, it seems worse since he bled the radiators last week. On the plus side, it is warmer and I have hot water.
The vibration starts when you can hear the water go in the boiler. If I move the knob on the actual radiator to a different setting, it usually stops (if it is on 3 and I move it to 5 and vice versa).
The past couple of days, I have had to turn the heat off to get it to stop. Does anyone have a suggestion that would:
a) get my landlord to believe me? He tried to replicate the noise but could not do it on demand. I held the phone to the radiator once, but that didn't help.
b) fix the problem?
Not sure if this makes a difference, but bleeding the radiators happens at the boiler, not on the radiators.
Thanks for any advice in advance.
Kind regards, lg
p.s. it is a small boiler. I think it's called 'on demand' but I'm not sure
b) fix the problem?
Kind regards, lg
