Ariston Microcombi overheating from firing continually
In the end it was the PCB that was replaced. This was more noticeable once the expansion vessel had been refilled which was causing the boiler to cut out earlier due to the pressure relief expelling water.
Following the re pumping the boiler would red light as was more normal for a damaged or broken pcb.
Thanks for the help and i hope this helps others in future.
