Hi Guys
I've been having problems with the DHW which fluctuates between hot and warm.
A British Gas contractor came round yesterday to look at the boiler and without opening it at all diagnosed a sludge problem and would benefit from a 'powerflush' or possibly a new boiler due to cost of 'powerflush'.
Anyway he's ordered some thermistors (I think) and said he'll be back in 2 weeks to fit the part but isn't confident it will fix it as he's adamant about a 'powerflush'.
I've read many alarming articles on the internet about BG's practices regarding 'powerflush' and getting the engineers to promote this service and although I'm not an expert on boilers (just a guy with common sense) it seems to me to be an expensive and intense way to rectify the problem especially as he didn't even take the casing off the boiler to take a look.
He also commented on that there's probably never ever been any inhibitor added to the system which I commented on and said that everytime I drain down the system I add more.
From a central heating point of view everything is working fine with no cold spots on the radiators at all and the house is nice and warm.
So could sludge be a problem?
As I previously stated the problem was that the hot water was fluctuating between hot and lukewarm with the pilot light going out for a few seconds then lighting up again this was happening with the DHW setting on 4 or higher.
After the BG engineer went I experimented more with the DHW and have discovered some more info.
I've now turned down the setting to 3 and now I have constant hot water.
Any help or comments would be most appreciated.
Regards
Regards
