Ashp pipes
11 Mar 2022
Hello,
Using ashp for central heating. Are 22mm pipes from cylinder with 15mm tails for rads sufficient?
Cheers
That depends on the flow rate, flow temperature and the rest of the information from the system design.
If you don't have that design, you can expect a poorly performing installation which will cost far more than it should to operate.
