I'm renovating a 1930s semi and abit unsure about this bit....I need to put in 50mm PIR board against the (solid) external walls and then build a stud wall in front. Upstairs the rafters "cutoff" the corner of the room. I've got a picture to help understand:
//www.diynot.com/network/Geps/albums/9255/35427
Can I just use the rafters to attach my studs to? I was then going to use insulated plasterboard fixed to the rafters and use rockwool to bridge the gao, taping where necessary to form a VP.
The loft has vents in the roof itself so I don't need to worry about the rockwool blocking off soffit vents etc.
Cheers,
Cheers,
