- Joined
- 11 Jul 2007
- Messages
- 440
- Reaction score
- 3
- Country
Converting attic to regs and ok standard.
Not wanting to take tiles off, couple of questions.
1 Should I put a membrane on the inside before I add insulation between the rafters? The roof seems good and no obvious leaks in the past.
2 slightly counter to last comment, I've white spores on the rafters near the ridge. It's dry to the touch, Aldi moisture meter reads around 27% on most rafters but some (along with some places on ridge beam) are off the scale.
My thoughts are the ridge needs re bedding/pointing.
But what to do with wood. Clean, sand, any treatment for the wood?
3 I need to build up party wall between for fire, but how exactly do you do it, up to tiles? Seal against them?
A couple of photos below
