I am having trouble with my Avus Architekt Thermostatic Bar Shower, in that when I try to increase the temperature 1) it isn't hot enough 2) the pressure drops significantly and the pump seems struggle.
It has been plumbed in correctly, with the recommended width pipework, and I have tried adjusting the thermostat to rectify the temp problem but it seems to make the pump struggle more. I have been told by a plumber that if a pump is fitted the ratio shouldn't be a problem, but there could be an issue with the return valves, if the shower has them. Can anybody suggest 1) where I might find the return valves 2) offer a practical solution to my dilema.
I have been in contact with plumbworld for over a year in regard to this issue, and have found them totally unhelpful. I have recently found out that I can only communicate with customer service and they don't have technical info.
