- Joined
- 30 Dec 2008
- Messages
- 1
- Reaction score
- 0
- Country
Hi, I have a back boiler for my hot water and c/heating. What I am confused about is currently I have no hot water upstairs. This is because when I moved into the property the previous person didnt use the hot water upstairs and there is a instantaneous water heater in the kitchen which provides hot water to the kitchen. I would like to get the hot water working upstairs. I have a cold water tank in the loft and a tank in my airing cupboard. How does the tank in the airing cupboard work? It may sound stupid but does it fill with water that is heated by the back boiler or is it to be used as an immersion tank? I've been told I need to disconnect the instantaneous heater in the kitchen and turn a pipe on under my stairs which should then send the water flow upstairs and I can then use the hot water. I know the hot water works upstairs as when I press the hot water timer button it works but what I dont know is, is it heating the water that has been sat in the tank in the airing cupboard for years or is it heating fresh water? and if it is heating the water in the tank, i'm concerned that without sending the flow upstairs by turning the tap under the stairs it may run dry. The tap is currently ceased up so thats another problem to tackle. It seems to have confused two plumbers that I have had round. My last resort is to contact some previous owners who I beleive installed the system and still live close by.
