Back floodlight - 1.5 to 2.5 cable
28 Nov 2005
London
HI,
Can anybody tell me what the implications (if any) of extended a lighting circuit (1.5 cable) to feed an outside light (150 Watts max), using a 2.5 arctic cable for the 'through the wall' outside connection? All other cable to and from the (new) switch will be 1.5.
crafty1289 said:
why do you want to? i mean, why use bigger cable than you have to?
Only because I have a couple of meters of 2.5arctic and do not want to use T&E on the outside of the house which, will not form the best watertight seal on the light fitting...
No problem as long as there is enough room to terminate it
