- Joined
- 15 Feb 2007
- Messages
- 30
- Reaction score
- 0
- Country
My central heating boiler is close to my hot water cylinder and above it. Consequently there is a gravitational flow from the coiled pipe inside the cylinder back up to the boiler. This occurs when the pump turns off. The result is that the water in the lower part of my cylinder cools down.
This only happens in summer. In winter my 'y' valve effectively stops this back-flow.
I think the problem might be solved by putting a non return valve in the pipe to the cylinder. But it would need to be one that opens with very little pressure. Has anyone tried doing this and is it possible to buy a suitable non return valve (22mm, preferably with compression joints)?
