Have a look under the fire towards the LHS...you should see the main boiler thermostat knob and piezo ignitor and to the left the overheat thermostat reset button and bracket.
You need the full kit...the sensing phial inserts into a tube that's soldered to the new flow pipe stub and the overheat stat wires connect into the thermocouple circuit.
we have established that you no longer have a cold feed as you previously had a spartan, put the x400 in anywhere you want it just gets diluted into the system water anyway
