balancing Radiators?
16 Feb 2010
Bedfordshire
If I balance a small radiator should i expect to see the same amount of temp drop as a large rad? cheers...
Yes, because the flow through a smaller radiator can be set less than a larger radiator.
This means that the water doesn't pass through the radiator as quickly as it would with a higher flow and therefore, because it hangs around longer has more opportunity to loose heat.
