- Joined
- 7 Dec 2010
- Messages
- 34
- Reaction score
- 1
- Country
I’m getting a bit confused with all of the different information about
Radiator balancing. And yes I have read several FAQ’s on the subject.
Is this correct
Reduce the flow within a radiator to allow the water more time to dissipate
It’s heat into the rad, therefore creating a greater drop. Obviously if the flow is reduced too much the rad temp will drop considerably but the drop will be considerable. At what point do you stop or do you just try to achieve 12 Deg C
and that’s it.
Is this correct
and that’s it.
