Hi
We have just had our gas mains changed from steel to plastic, balfour beatty have been doing this work (without problems and pretty efficiently i'd say). Anyway they turned off our gas for the day, to connect to the new pipes, and after reconnection everything seemed ok.
Their registered gas fitter came and purged our sytem? then reset the boiler and off he went, all was well.
That was three days ago, and now we can't get hot water.
Our boiler is a baxi 105e (not instant) and is 2.5 years old.
The heating works fine but no hot water, could any problems have arisen from the gas mains work do you think??? Everything was working for a couple of days after he left so it may just be coincidence.
There are no flashing neons to indicate a fault, the neon above the tap symbol does not illuminate on either CH/HW or just HW.
After reading into it, I had a look at the microswitch on the front of the valve, when I manually activate this switch the 'tap neon' then illuminates and the burner ignites but still no hot water. I didnt see any movement from the pin at the front of the valve.
any ideas anyone????????
many thanks in advance
beatts
beatts
