Ballcock Adjustment
16 May 2014
Aberdeenshire
Hi
The ballcock in the header tank in my loft very slowly passes water once its full. Its like the ballcock is sagging slightly and not fully shutting off the water. When I get up in the mornings there is a small puddle where it has seeped out through the overflow pipe. Nothing major just annoying. Can the ballcock be adjusted in any way or is it a replacement job?
What kind is it? If it has a brass arm it could be bent down slightly but may just need a washer.
Do as Denso13 says pop a new washer on, also unscrew the ball and shake it to see if it is leaking and partly filled with water.
Just been in loft and forgot my phone! Its a metal barrel coming through the tank with the arm held on with a split pin. Very basic. Ive bent it down as best I could but its solid and hard to bend. Its stopped it trickling out so Ill keep an eye on it
There should be a screw cap on the brass cylinder. Turn the water off, unscrew the cap, remove the split pin. You can pull the inner brass piston out with the lug on the ball valve arm. In the end of it there'll be a small rubber washer. Replace that, lube the mech up if it seems tight, reassemble (do check ball for water).
