I have a Glow Worm Energysaver 40e boiler which is approximately 9years old. A couple of months ago we started experiencing a loud banging noise from the boiler. When I lifted the front cover off I was quite disturbed to see when the banging noise happens a blue spark occurs at the bottom left hand corner of the boiler. The banging is at its worst generally after about 30mins of the CH being on. It does not happen when the hotwater is heating up.
I had a heating engineer around who replaced the pump to the left handside of the cylinder, however this did not work. He then advised that I needed a powerflush as the heat exchanger was being affected by sludge. This seems to be quite expensive to have done.
I have now also noticed a light dripping from the overflow from the loft area.
Would using introducing chemicals to the system help? Any other advice would be appreciated.
